Galant_martin
(Junior Member)
07/27/19 12:07 PM
ABS delete, rear delay valve?
Hello,
i did the ABS delete a time ago (abs unit out, new prop valve on the firewall and new lines for the fronts) and now i want to install SS breaklines. Now a rear hard line broke and i found something new. There is a rear prop valve and a abs delay block. Should i just uninstall both and connect both lines? I need a bit of new breakline to one wheel so i would order 2 connectors too.
Its a 2wd with solid axle and disc break
Generated in 0.011 seconds in which 0.008 seconds were spent on a total of 4 queries. Turbo powered.
