(Senior Member)
04/01/19 01:05 PM
Cad file for camber plates?
Anyone have a file for cad to make camber caster plates? I found a company takes files and laser cuts part for a reasonable price.
pagosadsm
(Junior Member)
04/01/19 08:38 PM
Re: Cad file for camber plates?
I have ground control camber/caster plates on my 92 talon. They fit fine, might have to drill 1 hole to fit them. I get 5* of caster out of them
(Senior Member)
04/05/19 11:59 AM
So... CAD file anyone?
(I ain't no puny human)
04/23/19 07:55 AM
I have some "domed" Tien plates I would donate for someone to use as a template, I only ask that I get a set in return. These could be flattened out and templated, I just don't trust using them as they are starting to crack.
(Hard Snarker)
04/23/19 07:00 PM
Yeesh. I take it you bottomed out the front a few times with those plates?
04/24/19 04:47 AM
I didn't, the PO of 148/1000 did. The AGXs these were used on were set to the lowest setting for the GC coil-overs. Needless to say, the struts were blown also.
mooserage
(New Title)
04/24/19 01:37 PM
Ouch.
I am guessing that Tektic will take this on, but if not, I'd be interested in using them as a template to have some made.
04/24/19 04:04 PM
Either way works for me.
Whoodoo
(buff guys = good time but my dream is to fondle 1051)
04/27/19 11:19 AM
How quick do you want it? I've been thinking about putting together a set of custom coilovers using the K-sport camber plates I bought years ago. The problem is, they are currently installed and I'm not super motivated to get the project done right now. If nothing turns up, I'll model them up when I get them off.
04/27/19 09:18 PM
How ever fast you can do it. I am not using them currently, since they have a crack and are domed. They could be flattened, but I dont want to send my struts through the hood.
AllanL
(Heal and Toe)
05/04/19 09:22 AM
Lost the drawing so getting it redrawn...
Needs some time though...
idreamidrive
(Member +)
05/05/19 09:29 AM
I have dsm camber plates (the camber slots would need to be rotated 90 degrees for galants unless you want them to be caster plates) that I could donate to the cause.
AllanL
(Heal and Toe)
05/06/19 09:39 PM
Quoting tektic:
do you still need the CAD drawing?
AllanL
(Heal and Toe)
05/06/19 09:52 PM
Quoting tektic:
here's a draft...i'll send .pdf if you still need...
(Senior Member)
06/09/19 11:26 AM
Quoting mooserage:
Ouch.
I have so many things going on right now... I'm out of service last 3 weeks with a concussion.
(Senior Member)
06/09/19 11:28 AM
Thank you Allan. There's a link in the first post if you could could you send them the file and ask for a quote?
(Senior Member)
09/03/19 04:58 PM
Working in solid works now, anyone have measurements for the hole spacing? I have a few designs I'm thinking up.
AllanL
(Heal and Toe)
09/06/19 02:18 AM
which holes?
CutlassJim
(poop load of room)
09/06/19 06:35 AM
Quoting tektic:
Same. If someone gets me a drawing with dimensions I can model it and could 3D print you a prototype to test fit.
AllanL
(Heal and Toe)
09/06/19 07:50 PM
you need the rear as well?
(Senior Member)
09/08/19 11:16 PM
Thank you again. I drew up a pretty decent camber/ caster plate. Does anyone know a good source for spherical bearing plates? The bottom plate with the cup a bearing gets pressed in to it.
I drew up a 5 piece system with off the shelf radial and spherical bearings. It would be easier to get made if I just needed to make the one plate though.
CutlassJim
(poop load of room)
09/09/19 09:01 AM
The plate with the cup/bearing in it is going to be a custom made part. Either that or source one from a manufacturer that will sell just that and design your camber plate to be compatible with it.
09/09/19 10:53 AM
If TEIN still has them, they would be a good source. My plates were TEIN, they just got domes from the PO running at full drop and definitely bottoming the suspension out. We found evidence of it from the undercarriage,
AllanL
(Heal and Toe)
09/09/19 08:15 PM
if anybody has tein or cusco bearing housings for any car, these are universal, I believe.
and will fit.
the drawing i provided for a 6g galant-specific cusco plate.
(Senior Member)
09/11/19 01:23 PM
I've reached out to a few places for parts an most have just said no. Pretty lame. I guess I'll be looking to make some? I'll try Cusco first. Thanks.
(Senior Member)
09/11/19 03:40 PM
Camber caster plate draft set up for Cusco bearing flange
AllanL
(Heal and Toe)
09/12/19 01:38 AM
maybe G ha some sources of non-Mitsu CUSCO camber plate assemblies..?
just snag the bearing housings...
G
(JDM Unit)
09/14/19 12:12 AM
Why not buy the cusco camber plates?
(Senior Member)
09/14/19 10:24 AM
They list for $290 and have no caster adjustment.
09/14/19 11:01 AM
FR Sport list them for less than 290 with camber adjustment HERE
(Senior Member)
09/15/19 01:42 PM
"Caster"
where should I spend my $2 ? Lol
Hey Tom how thick were those tein plates? I want to make sure mine don't dome like that.
09/15/19 06:52 PM
1/4 - 3/8 inch in thickness. I think anything will dome if you bottom out the suspension as much as the PO did. We even found dents in the under-body near where the sub-frame mounted, so it saw some serious hits.
Generated in 0.007 seconds in which 0.005 seconds were spent on a total of 4 queries. Turbo powered.
