pot
(It's a twee shaker----choot him choot him)
01/19/16 05:44 PM
FS: '91 Gvr4 Partout (xxxx/2000) NB *Updated June 19, 2020
FS is everything from an unbadged non-sunroof 1991 Galant vr4. This Galant has 151,910 miles on the odometer and was originally Nile Black.
All parts prices include PayPal fees & Shipping Costs for CONUS based transactions. First come first served.
I accept all payments via PayPal to: [email protected]
For inquiries please contact me via PM or mobile no (910) 689-6150. Thank you for looking!
Engine
Camshafts, Stock $30.00 each
Cam Cap Bolt Set $15.00
Rocker Arm Set $20.00
Crank Pulley Bolt w/ washer $8.00
Front Engine Mount $15.00
Water Pump Pulley Set $15.00
Resistor Pack $40.00
Fuel Rail Bolt Set $2.00 plus shipping
Fuel Feed $5.00 plus shipping
Lower Rear Timing Cover $15.00
Rear Upper Timing Cover $15.00
Banjo (Coolant) $3.00 plus shipping
Starter *Remanufactured $30.00
BOV $25.00
Harmonic Balancer Bolt Set $2.00 plus shipping
EVAP Line *Connects to Charcoal Canister $2.00 plus shipping
Body
Headlights $100.00 for the set or $65.00 each
Cowl Panel $50.00
Front Windshield Side Trim *Passenger $15.00
Hood Latch $8.00
Horn $8.00
Cowl Panel Trim $5.00
Front Driver Dogleg $30.00
Hood Release Cable Guide $8.00
Hood Bumper Set $5.00
Radiator Fan $15.00
Windshield Wiper Set *Driver Air Spoiler missing $35.00
Accelerator Cable Guide $3.00
Fuel Filter Bracket $3.00
Hood Release Cable $12.00
Throttle Cable Guide *On Passenger Strut Mount $3.00
Exhaust Hanger $8.00 each
Window Regulator $30.00
Front Driver Interior Door Wiring $20.00
Door Sensor Set $20.00 or $8.00 each
Door Latch Set $15.00 or $4.00 each
Rear Passengerside Quarter Window Glass $35.00
Rear Driverside Quarter Window Glass $35.00
Fuel Door $15.00
Fuel Door Cable $12.00
Trunklid Ajar Switch $8.00
Rooftrim Clips Set $5.00
Rear Top Window Molding $30.00
Rear Bottom Window Trim $50.00
Trunklid Catch $5.00
Tailight Socket $5.00
Rear Decklid Wiring Harness $30.00
Interior
Dashboard Vent $2.50 each
Dash Speaker Cover *Only Driver side is available $12.00
Hood Release Lever $8.00
Horn Pad $15.00
Glove Box Frame $10.00
Glove Box Striker $5.00
Glove Box Reinforcement Bracket $3.00
ECU Tray $10.00
Lighter $3.00
ETACS $40.00
Chassis Control Module part no MB801352 *Alarm $40.00
Driver Side Visor $15.00
Rear View Mirror $15.00
Mirror Cover $8.00 (Non-Sunroof)
Outlet Bezel $15.00
Shift Cable Clips $1.00
Center Console Side Covers $12.00 each
Center Console Trim $12.00 *Mirror Adjustment Switch sold
Retractor Mounting Bracket $15.00
Retractor Shoulder Belt $30.00
Control Unit Auto Seat (Part No MB617345) $20.00
Seat Headrest $20.00
Seat Height Adjustment $5.00
Seat Hardware Cover (Driverside) $8.00
Amplifier & Radio Antenna Cable $25.00
Gas Pedal $20.00
Clutch Pedal $50.00
Clutch Interface Switch $12.00
Clutch Switch $12.00
Stoplight Switch $12.00
Front Seat Hardware Set $2.00
Front Passenger Door Speaker Cover $15.00
Driver side Speaker Cover $15.00
Door Knob Trim $.50 each
Door Handle Backing $3.00 each
Interior Door Handles $5.00 each
Interior Door Pull Handle $5.00 each
Oh Shit Handles $5.00 each or $15.00 for the set
Driver Window Switch $40.00
Front and Rear Passenger Window Switch $12.00 each
Door Card Clip $1.00 each
Front Passenger Rear View Mirror Trim $3.00
Driver Door Handle Deadpanel $3.00
Rear Door Ashtray $5.00
Doorcard Light $5.00 each
Front Scuff Plate $12.00
Passenger Rear Scuff Plate $12.00
Driver Rear Scuff Plate $12.00
Ash Tray $8.00
HVAC Bezel $30.00
HVAC Knobs $1.00
Buzzer $3.00
Center Console Side Panel Insert $15.00
Trunk Dome Light $3.00
Rear Driverside Seatbelt $20.00
Rear Defroster Heater $3.00
Trunklid Hinge Stay Set $15.00
Steering & Suspension
P/S Reservoir $25.00
P/S Reservoir Bracket $3.00
Lower Plate & Stopper Set *Front Subframe $5.00
P/S Rack Mount Bracket $12.00
Front Passenger Control Arm $25.00
Clamp $15.00 each
Front Swaybar Brackets $10.00
Rear Swaybar Bracket Set $5.00
Swaybar Endlinks $12.00
Rear Steering Rack Mounting Hardware Set $3.00
Rear Crossmember Mount $15.00
Rear Driver Upper Control Arm $20.00
Rear Upper Passenger Control Arm $20.00
Rear Shock Dust Cover $2.00 each
Rear Shock Mount Bolt Set $3.00
Rear CV Axles $40.00 each plus shipping
Rear Lower Control Arms $20.00 each
3 Bolt Cups $20.00 each
BRAKES
Brake Master Cylinder $15.00
Front Driverside Brake Line $15.00
Rear Brake Caliper Brackets $20.00 each
Parking Brake Retainer $3.00
ABS Motor $75.00
ABS Proportioning Valve $15.00
Front ABS Sensor $20.00
ABS G-Sensor, Front $20.00
ABS G-Sensor, Rear $20.00
Electronic Control Unit (ABS) $40.00
ABS Connector Bracket $3.00
Brake Fluid Reservoir $12.00
Brake Line Mount $3.00
DRIVETRAIN
Flywheel Bolt Set $5.00
Pressure Plate Bolt Set $2.00
Clutch Line to Slave Cylinder $8.00
Stainless Clutch Line $12.00
22 Spline Transfercase $150.00
Sleeve Yoke $15.00
Center Yoke $15.00
Rear Propeller Shaft Bolt Set $3.00
Rear Differential Bolt Set $10.00
rallyvr4
(Newbie)
02/13/16 05:01 PM
Re: FS: '91 Gvr4 Partout (xxxx/2000) NB
I'm in need of a front sub frame?
15psi88
(Member)
02/14/16 08:56 PM
Would you be willing to cut the roof skin off?
If so I can have it picked up.
Lostkoz
(Newbie)
03/26/16 03:25 PM
Looking for the weather strip that sits in between the front windshield and roof of the car. Also need the driver side rear plastic 1/4 panel piece(not sure of the specified name. I can post a pic if that helps.
johnnyRacer
(Member +++)
04/17/16 10:00 AM
Throttle body bolts?
4Grim
(I deliver.)
09/12/16 12:56 PM
Re: FS: '91 Gvr4 Partout (xxxx/2000) NB *Updated September 10
Hey Pot...just PM'ed you a part I need.
Thanks man.
Rrohde84
(Junior Member)
09/12/16 01:30 PM
hey do you have a working factory radio?
OldHairyBastard
(I take bottom on trannies)
09/13/16 11:50 AM
Breaker and Profec B are SOLD!!!!
youngbuz
(Newbie)
12/20/16 10:11 PM
Re: FS: '91 Gvr4 Partout (xxxx/2000) NB *Updated November 26
hello im from sydney australia and need the rear bumper asap how much are you looking for ????
scottinalaska
(Junior Member)
12/21/16 03:08 PM
Re: FS: '91 Gvr4 Partout (xxxx/2000) NB *Updated December 17
Battery hold down hardware?
JamesFoster
(Infamous BMX Master)
12/21/16 09:07 PM
Passenger door?
MoeJz
(Newbie)
01/03/17 05:42 PM
Re: FS: '91 Gvr4 Partout (xxxx/2000) NB *Updated January 2
Hello,
I am looking for Passenger side door handle ( Outside ) .
Thanks,
Moe
Pushinink
(Junior Member)
01/28/17 10:40 AM
Re: FS: '91 Gvr4 Partout (xxxx/2000) NB *Updated January 7
how much for a gauge cluster?
MauricioBolivia
(Newbie)
02/02/17 09:54 AM
hi shipping to south america ? Bolivia ?
regards
Mattwood
(Newbie)
06/17/17 08:56 AM
Re: FS: '91 Gvr4 Partout (xxxx/2000) NB *Updated June 3
I'll take the passenger side speaker cover and AC bracket if still available
Mattwood
(Newbie)
06/21/17 07:40 PM
Re: FS: '91 Gvr4 Partout (xxxx/2000) NB *Updated June 17
Is the Alternator bracket still available?
chaoticdopey
(Newbie)
08/22/17 12:46 AM
i need the driver seat or just the driver seat rails
supersp0rt2
(Junior Member)
04/20/18 12:16 AM
Interested in the lower control arm set.
E39_VR4
(Newbie)
04/21/18 11:59 AM
Re: FS: '91 Gvr4 Partout (xxxx/2000) NB *Updated April 20th
Need headliner board and the two small lower trim panels on each side of the console. Would you by chance have the complete seat bases,just the sliders and all the associated mechanisms, with the trim panels? Don't need the seats themselves. Please PM with prices and availability. Thanks!
E39_VR4
(Newbie)
04/21/18 12:04 PM
BTW, if need be, I could come and pick up those parts, headliner would be very difficult to ship, I would think.....
CutlassJim
(poop load of room)
04/21/18 06:21 PM
Rear passenger door handle?
cptncreme
(Newbie)
04/25/18 06:07 AM
Pm sent
arapp
(Newbie)
08/16/18 11:10 PM
Re: FS: '91 Gvr4 Partout (xxxx/2000) NB *Updated August 16th
Does your parts car have an automatic retractable radio antenna? I need the male harness and clip that plugs into the antenna motor, mines been damaged.
AKGVR4
(Newbie)
09/08/18 10:41 AM
Pot, do you have any stock wheels? doesnt matter which year Thanks
a2vr4
(Boot Strap Bill's boy)
09/24/18 08:17 PM
Do you have the mpi?
Deboelduro1
(Newbie)
09/26/18 12:31 AM
Re: FS: '91 Gvr4 Partout (xxxx/2000) NB *Updated August 23rd
I also need a battery tray ?
Nabeel
(Member +)
01/10/19 02:45 PM
Re: FS: '91 Gvr4 Partout (xxxx/2000) NB *Updated January 4th
Fuse-Relay box + Man radiator fan speed controler (the small box attached to the fan frame)?
Rrohde84
(Junior Member)
03/14/19 10:07 AM
Re: FS: '91 Gvr4 Partout (xxxx/2000) NB *Updated March 10
steering rack by chance
Rrohde84
(Junior Member)
03/15/19 10:34 AM
would you know where to get one
Mattwood
(Newbie)
03/18/19 10:26 AM
Is the j-pipe of the turbo still available and if so can you send me pictures thanks
newbie
(Newbie)
06/14/19 12:54 PM
Re: FS: '91 Gvr4 Partout (xxxx/2000) NB *Updated June 2nd
i need the ashtray shipped to 98065. let me know how much.
Stevenoly
(Newbie)
07/29/19 01:55 PM
Text sent. Looking for a left hand rear dogleg trim piece along with the c-pillar trim shipped to 98275.
Vr4s
(Newbie)
09/17/19 10:45 PM
Re: FS: '91 Gvr4 Partout (xxxx/2000) NB *Updated June 29th
Hi there. Do u have idle control value for cyclone throttle body? Thx
ihugzombies
(Newbie)
09/18/19 01:12 PM
Do you have the valve cover for sale by chance?
E39Alfa
(Newbie)
09/24/19 04:54 PM
Sent you PM about the front ABS sensors, ABS ECU and interior chrome door handles.
(Turn Right Racing)
09/25/19 08:01 AM
Not stealing Pot's business, but if he doesn't have them, I may have the ABS parts.
E39Alfa
(Newbie)
09/25/19 04:46 PM
Ok, thanks will let you know if things doesn’t work out with him
E39Alfa
(Newbie)
09/26/19 08:39 AM
Payment sent for both ABS sensors, thanks
DTinker187
(Newbie)
11/05/19 07:20 PM
pm sent!!
ka24det92
(Newbie)
02/16/20 04:32 PM
Re: FS: '91 Gvr4 Partout (xxxx/2000) NB *Updated February 7, 2020
Any ac parts left?
Zee
(Member)
02/16/20 08:36 PM
I need complete engine harness... Is it available? Msg me or email [email protected]
Thanks zee
ka24det92
(Newbie)
02/20/20 11:09 AM
All the engine bay ac lines and the compressor bracket
ihugzombies
(Newbie)
05/07/20 03:33 PM
Do you have the center dash A/C vents ?
4Grim
(I deliver.)
05/08/20 06:45 PM
Re: FS: '91 Gvr4 Partout (xxxx/2000) NB *Updated April 23, 2020
Is that starter a OEM unit that's been remanufactured? I see the sticker World Class remanufactured but not sure if that's a aftermarket company or the shop that actually rebuilt it?
pot
06/17/20 09:18 PM
Re: FS: '91 Gvr4 Partout (xxxx/2000) NB *Updated May 25, 2020
Bump. I have a huge supply of off the shelf stock OEM galant parts, bolts, other hardware, etc. No part is too small or too large.
Please feel free to message me or text/call: (910) 689-6150. Thank you for looking.
Generated in 0.005 seconds in which 0.003 seconds were spent on a total of 4 queries. Turbo powered.
