287/2000 Ryan's VR4
Clean and Uncomplicated Example of a VR4
Specs
Ownership Status
Currently Own
Year
1991
Production Number
287
Mods-Power
ETS intercooler & 2G Elbow
Thermal R&D 3″ stainless turbo-back exhaust
Nightshift coil-on-plug ignition
Fuel Injector Clinic 1050CC injectors
255 Walbro fuel pump
Forced Performance aluminum intake & exhaust manifold
16G Turbo
Tial Q BOV
Tial MVS 38mm wastegate
Hallman Pro Manual boost controller
Mods-Drivetrain
Rebuild 4 Bolt rear differential swap
Rebuilt transmission & transfer case
ACT chromoly flywheel
Centerforce dual friction clutch
Stainless clutch line
16” Powder Coated Advan RC Rally and Dirt Trials
Continental Extreme Contact DWS06 205/50R16 tires
Mods-Engine
6 Bolt motor bored .20 over NR 8.5:1 2G pistons and OE 1G rods
ARP head studs, rod, and main bolts
264 Delta exhaust and intake cams
Evo 8 valve springs & retainers
Kiggly HLA
Topline 3G revised lifters
ACL oil pump
Balance Shaft and EGR deleted
Fluidampr harmonic balancer
3.5″ GM MAF with direct fit harness
Zaklee clear timing cover
Mishimoto radiator with x2 slimline fans
Mods-EMS/Tuning
Eprom ECU with ECMLink V3
AEM wideband
Autometer vac/boost
Mods-Handling
Powerstop front & rear pads
StopTech slotted rotors
H&R lowering springs
KYB struts
Custom rear adjustable control arms
Polyurethane bushings.
Whiteline rear sway bar
Bulfab tubular front crossmember with arms
Avid Tuning urethane engine and trans mounts
Cusco front & rear strut bars
Rebuilt rear subframe with poly bushings and RWS rack delete
Mods-Exterior
JDM front & rear bumpers
facelift projector fog lamps (JDM)
Eterna grille (JDM)
93 Galant clear headlight housings
JDM AMG amber corner lights
Carbon Fiber JDM vented hood
Mods-Interior
MOMO steering wheel
JDM dash mat
JNZ clutch pedal assembly
Custom VR4 floor mats
VR4 lighted leather shift knob
Ortiz custom gauge pod
HKS turbo timer
6.5” Alpine Type R rear deck speakers
5.25” JL Audio front speakers
Pioneer Head Unit
Car information
Added by
HollywoodHalo560
Views
709
Last update
More in 1991-1992 Galant VR-4
